i just finished building a nh hit-n-miss engine which is my first model engine.and at assembly time i lubed all part liberally. but even with the oilers all the way open things are getting sticky. and as of this time i only used 10-30 motor oil and the Cly. doesn't seem to be getting enough lube, but the other bearing with cup oilers are fine.
there is a hole in the side of the piston which allows oil to drop through at the bottom of the stroke to lube the wrist pin assembly which seems to be working fine, but the Cly. gets real dry when i run the motor. and there is about .002" between the Cly. and the piston which is starting to show signs of wear and it only has about 10 min run time in short runs like maybe 6-10 rev. which i am getting it to run better fooling around with the timing and carb settings.
so which oil should i use or is there something else i should be looking for?
