I purhased a cheap Wickes Grinder for about 25 quid a few years back, used it for grinding up old brick bolsters and cold chisels for cutting up paving slabs and chanelling out brickwork etc.
It was obviously rubbish but was good enough for the work I wanted. I put a couple of buffing mops on it now and use it for a bit of polishing.
Now, I'm in the market for a bench grinder, problem with the wickes one was that there was no real shoulder machined on the shaft and the wheels were just held in with little thin pressed washers, so the wheels shimmied around like they were doing the macarena...
I'd like to buy a reasonably nice quality grinder for grinding lathe tools, one with nice decent sized rests which can be adjusted, which is true running and reasonably well built. I dont really want something which is continuosly rated as it won't really get heavy industrial use!
Can anyone here recommend one? 6" or 8". I only have a small lathe so would be grinding upto 3/8" Lathe Tools and sharpening drill bits etc. Creusen, Axminster etc - UK Suppliers only please!
Alan
(Not sure if these is an "I WANT!" post or "CAN I HAVE?" post!)
Alan
