What kind of engine is this?
Nickademusss
Found this little gem at a antique store today marked as telegraph equipment, it does run off of a 9v battery, I plan on restoring it. The only markings are on the connecting rod, it says Pat D May 17 1910, its 5" long 2.5" wide with a 2 3/4" fly wheel. With a forward and reverse lever....
Anyone ever seen one of these?
http://s826.photobucket.com/albums/zz182/nickademusss/?action=view&current=IMG_0741.mp4
I have seen a lot of solenoid engines, but that may be the oldest one I have ever seen.
Nice find! Thm:
Rick
You might find this of interest...
[ame=http://www.youtube.com/watch?v=8aWobDU0Cm0]http://www.youtube.com/watch?v=8aWobDU0Cm0[/ame]
That is about enough to get me in-to building an "engine". :)
I wonder what sort of contacts and how the speed control works.
The rest is no problem.
To the OP can you determine the mechanism involved?
...lew...
I sold a motor of that exact type on eBay a few months back. My example had the same patent date. It was a bit cleaner with nice paint and perfect wiring. It'll run on just about any voltage greater than 2.5V. A couple of D-cells will have it ticking over nicely.
Mine sold for something like $250... Your $15 find is probably worth $200 in its current condition.
The only reason I sold mine was because I am personally not interested in solenoid engines.
WOW :) thanks for the info, I will carefully restore it, and it will live on. I am just glad the coils dont need to be rewound.
their are some numbers on the bottom I noticed today, 1012 is what it says, could that be the cast date of the base, october 1912?
I also think it needs a nice wood base with a battery compartment.
Looks like something from a high school physics lab.
It does! I am just stoked to have a 100 year old electric motor, after cleaning and oiling, it will run very slowly on a set of AA batteries or fast if you want...
I have some contact lubricant that made it run better as well, I think the little brushes will last longer with it on them.
