student123
- Oct 31, 2009
- 183
- 0
On a novice build of the littlemachneshop oscillating engine
http://littlemachineshop.com/Projects/OscillatingEngine.php
I have a Taig lathe & a cheap & cheerful drill press.
Will be test running on compressed air.
I've drilled the two vent holes in the ali upright, for one hole drilled 2.5mm then tapped part way through 3mm for the inlet connector to fit into.
(the second hole I drilled 3mm in error, but that can be an outlet vent -unless I can glue a tube in place?)
To create a 3mm conector my plan is to drill through the shaft of an M3 bolt (ie to create a tube with an M3 ext thread). What diameter hole should I drill?
Alternative suggestions welcome.
Mike
Mike
