student123
- Oct 31, 2009
- 183
- 0
On a novice build of the littlemachneshop oscillating engine
http://littlemachineshop.com/Projects/OscillatingEngine.php
I've added a bearing & done the crankshaft differently, (pic below)
Both the crankshaft & upright is ali. After some problems, I ended up d/t the flywheel centre with 6mm int thread.
Bearing inner diameter is approx 6.8mm . Ive turned the crankshaft so the bearing goes on as a tight fit
so outer diam of crankshaft is approx 6.7mm. I've d/t an iner diameter for a 6mm thread, so wall thickness is approx 0.35mm. It feels ok to me + will have a bolt going in , so I'm assuming it will be safe one the engine is running
( presumably there must be a point where a thinner wall would become unsafe)
If its relevant I also plan to do a similar internal thread to fit the crank disc to the crankshaftother side of the upright.
'Is my assumption about 0.35mm thickness being safe correct ?
Hands up I cut the recess for the bearing in the upright the wrong way (a hack with drill , mill, Dremel & file)
So now need to pack the upright around the bearing. I have a pack of modelling clay in the shop. Dries hard in air. Is using clay a not-so-clever idea?? If so, whats best to pack around the bearing?
Mike
Mike
