student123
- Oct 31, 2009
- 183
- 0
On an ongioing novice build of the littlemachineshop oscillating engine
http://littlemachineshop.com/Projects/OscillatingEngine.php
I have a Taig lathe & a cheap & cheerful drill press & a cheap & not-so-cheerful airbrush compressor.
My first attempted build, was abandoned , one of several problems being the port holes not properly aligned.
http://www.homemodelenginemachinist.com/index.php?topic=9657.0
Have completed assembly of a second engine:
I've put compressd air on , no movement.
This new engine ,after measuring several times & using a tin template I've again managed to not get the vent holes fully aligned
Best way I can describe it is , lookin thru the holes in the upright uou can see 'moon phase' shapes
heres a pic
the black bits are where port vents do go thru to the cylinder
Julian mentioned in my earlier post timing in this context but not sure what it means (google for timing & engines brings up IC engine stuff)
What now can I just make the holes in the upright bigger?
Mike
heres a pic
Mike
