Runner
- Feb 10, 2011
- 124
- 17
Hi all,
I am building a 3.5" gauge locomotive based on LMS Black 5. The plans I am producing as I go along after studying pictures of the locomotive available on the internet. However, the Walschaert Valve gear has construction detail that is hidden on the completed locomotive. The area of concern that I am struggling with is in the area shown in the attached sketch. The die nut, I assume travels the length of the link, depending upon whether forward or reverse is selected. Forward the die nut is below the pivot on the link and reverse it is above it. Therefore it must travel past the position where the link is pivoted to enable the eccentric rod to impart motion to the link. I assume that the radius rod/die nut connection is as drawn. Please confirm. But how is the pivot constructed to enable the link to rotate but still allow the die nut to travel past the pivot point.
Thanks in advance,
Brian
Thanks in advance,
Brian
