D
Don Huseman
Guest
I got a knock of Kurt vice. What a nice vice. I have a 4".6" and 8" regular old milling vices and as far as I am concerned they are all for sale. This vice just is so nice. I was thinking that instead of using parales to hold parts of the bottom or above the vice jaws I was thinking of taking the vice jaw out and drilling through both jaws at the same time with a carbid drill and putting in dowel pins in them. I would have to drill and tap the dowel pins to pull them out with a little screw, but it would be a slick way of setting in parts parallel and level in the jaws.
I am also thinking of milling in two 45 groves in the vice one set vertical and the other horizontal. I was thinking that I would first mill a square grove in the jaws first and then go in with a 45 degree cutter after words.
WHAT SAY YOU ALL ABOUT THE DOWL PINS AND THE GROVES.
By the way I had to open the jaws to 7 1/2 " After contemplating pick up a hindered pound vice and putting my old 8" milling vice on the table that vice must weight 135lbs I noticed that the jaw could be move to the outer side of the fixed jaw and removing two Allen bolts and re bolting them on the other side of the fixed jaw would be a lot less time and a lot less hernia operations.
What a nice vice.
What a nice vice.
