velocity myford ML7
troll
I have myford ML7 with pulley motor 3 1/2"
Which is the nominal speed? pulley 2 1/2"
thank you
Troll, for 1450 RPM 50 Hz with a 1 7/8" motor pulley spindle RPM is:
Straight Back gear
1 200 35
2 357 62
3 640 110
and with a 2 1/2" motor pulley:
Straight Back Gear
1 273 47
2 487 84
3 870 152
May I be so bold as to suggest that you invest in a copy of "Myford Series 7 Manual" authored by Ian Bradley ? - it is really inexpensive and worthwhile to have around for your Myford Thm:
Kind regards, Arnold
I'll second Arnold's suggestion - every Myford owner should have a copy of that book!
Straight Back gear
1 200 35
2 357 62
3 640 110
Straight Back Gear
1 273 47
2 487 84
3 870 152
the smaller pulley was for the babit bearings and the lager was considered the high speed one for the bronze bearings. 640 is the max you want to run with babit main bearings
Stuart
Stuart
Stuart,
I am very curious about the above and why this is so. Many machines with babbit, (whitemetal), bearings run at higher speeds than 640. At higher speed the more likely you are to have hydrodynamic lubrication, without forced lubrication.
Best Regards
Mine runs around 750 rpm and has done for many years, quite a lot of my stuff is done at the top speed but there has been no measurable wear thus far. I would think Myford were well and truly erring on the side of caution.
maybe they were cautious with the speeds , maybe thats why they last well
the export ones with 60hz motors ran at a higher speed with the same pulleys due to the faster motor speed
AFAIK the larger pulley was a high speed option
My big bore runs at 3k rpm buts thats on the bronze taper bearings only two speed ranges tho with back gear only recommended on the lower one .
I do take advantage of the higher RPM eg today I was extracting a petticoat pipe out of a 3 inch length of 2 1/2 dia brass at 1500 rpm using HSS zero top rake of-course
the book mentioned in earlier posts dose give the normal spindle speeds
Stuart
I have altered the speed of my Myford ML7 by doubling the diameter of the pulley attached to the motor. I've found this to be really good for turning small diameter work and I've also found that the range of speeds I now have is much more useful. However, I did run into some trouble with the countershaft bearings. They were bronze bearings but were damaged after some use at the highest speed. The shaft was also damaged so I've since re-machined the shaft to accept ball bearings. Since then I have had no trouble at all running my ML7 at higher speeds. If I have any trouble with the main bearings I'll probably investigate doing something similar. Perhaps spindle bearings or something like that are available. I have a picture of the bearings I put in:
Hope this is interesting to someone,
Ben
Thanks to all
A friend I give myself a meter of rpm
countershaft to 621 rpm
lathe spindle to:
380 rpm
640 rpm
1100 rpm
