I am in the process of building a Henry Ford First engine but with over head valves. I have made the valve stems out of 1/8" hardened dowel rod. What I have in mind for a keeper is grooving the end of stem to take a wire wrapped around once like a piston ring and a brass keeper with a tapered end to "trap" the wire and force it against the valve shaft trapping the keeper and spring from coming loose. What I ask is this a viable idea and has any one else done this? THANKS john
(at a later date I will attempt to make this a hit and miss after it runs and is the reason for the over head valves.)
