I'm posting this here because Marv Klotz inspired it's construction here with his thread
..http://www.homemodelenginemachinist.com/index.php?topic=8815.0
I had to recut the dovetail after mucking up the first attempt detailed here..
http://www.homemodelenginemachinist.com/index.php?topic=10547.0
This is the first slightly complex device I have made from scratch and I thank Marv for
giving a build sequence to get started.
Fixed the dovetail problem by starting over and being more aware of the cutter's limits.
Created the grooves using the Rotary table for the first time and the cutter is a 3mm round nose endmill.
Finished with camera mounted
I had to alter the 82 degree foot mounting screw countersink to 90 degrees to suit my countersink cutter.
As a beginner I learned a lot making what to most of you is a simple project.
