Niels Abildgaard
- Jun 13, 2010
- 540
- 94
Chuck Fellows started a thread on homemade tangentials
http://www.homemodelenginemachinist.com/showthread.php?t=10702
with a round HSS toolbitt
http://s192.photobucket.com/albums/z195/cffellows/8b077207.jpg
In the mean time I have had fun making tangential holders
http://imgur.com/U3sK5bE
From left they are
Three press manufactured(4 hours making time each)
The first uses a 3/16 Crobalt bit that has one of its corners modified to 85 degree to go easily into corners without grinding top face with a rather obscene angle of 30 degree or more.Next is 5.3mm carbide treated same way and last is a rather expensive triangular carbide bitt.
The middle one was a test to make a holder even faster and is described somewhere in original thread. I do not like it.
The three last are the Rolls-Royces .First two are wire-sparked by a professional and the uttermost rigth is made by me as pure lathe work.
As You can see it is using a round 4mm discarded carbide endmill free and of good parentage.
Idea is that Carbide is nice but beasts to regrind for tangentials
For cutting steel I very seldom(never?) cut more than 2 mm deep and a 4mm round is apprecially less grinding than the 5.3 mm square one.
It works well on my extremely rigid Boxford lathe,but I really do not know if it is an advancement of the art.I have no QCTP with carbide and cannot really compare.It is 25.48 mm top to bottom at the moment and can easily be taken down to 22mm,or shimmed up of course.If someone want to try it and write a few words here it is up for grabs.
Kind regards
Niels
From left they are
Kind regards
Niels
