- Jan 4, 2011
- 1,348
- 354
I have an ignition timing mystery. I have built the Two Bit Twin as posted on Model Engine Maker. I have been having a problem getting it to run. I could get one cylinder to fire but not both at the same time. It would seem to fire on one cylinder and the other cylinder would misfire like the timing was too far advanced. This engine is a 50° offset so I figured that the cylinders had to fire at 410° or 310° (360 + or - 50°) Since I am using a wasted spark ignition and triggering the hall sensor off from the camshaft I thought that the magnets had to be 205° apart. After screwing around with all kinds of carb setting, valve timing etc I finally checked where the cylinders were actually firing. If I set cylinder #1 to fire just before TDC cylinder #2 fires 15° BTDC. I finally made a new magnet mount with the magnets set at 220° and the engine took off. I still have some tweaking and cleanup to do but the engine runs. I have no idea where the extra 15° came from but it runs.
![1686942814269.jpeg 1686942814269.jpeg](https://cdn.imagearchive.com/homemodelenginemachinist/data/attach/101/101920-1686942814269.jpeg)
