Tapered chuck staying in millshaft
Help Support HMEM:
MARK ROBINSON
New Member
lango
Hi all does anyone have any tips on securing a tapered chuck into a vertical milling machine as tip does not allow for the draw bar to be screwed into. have tried tapping with hammer etc. damaged two pieces now with chuck dropping when performing a milling task. i do have a collet chuck which works fine the a couple of mills i have do not fit in, so have to use a standard mt3 tappered chuck.
RM-MN
Find out why that drawbar doesn't screw in. It should. It may need a different diameter or different thread.
Jasonb
Surrey, UK
Get a collet that fits the cutters you are trying to use.
Is this a tanged MT3 taper with a drill chuck on it, if so not a good idea to hold milling cutters in a drill chuck as they will pull out even if you change the arbor to one that takes a brawbat
MARK ROBINSON
New Member
lango
Thank you all assumed it was ok to use as is what came with the v20 chester mill from new? will invest in a bigger collet range
Jasonb
Surrey, UK
They are sold as Mill-drills and most will come with a drill chuck though often the MT taper is the threaded type for a draw bar. It would be worth thinking of changing the arbor to a drawbar one anyway as easier to eject than a tanged one and not going to drop out but don't use it for milling.
https://www.arceurotrade.co.uk/Catalogue/Chucks/Drill-Chuck-Arbors
