Tangential Tool holder
Omnimill
There have been a few posts about these, this is my collection. Three home made and one commercial.
The bought one is the black one with a round bit. I need to make a right hand version at some point!
This is the most used one.
Sharpening jig.
Height setting gauge.
The home made holders do look far better than the commercial one does!Thm:
I found that if I rotate the bit 90 degrees clockwise, my tangential tool works as a vertical shear bit.
It is only good for taking off poofteenths of a mm and I am not sure the angle is optimum.
Just thought I would share.
Jim
Not tried that. There is a shear tool half way down this page.
http://www.conradhoffman.com/advancedsharp.htm
This is great stuff! It puts the very old fashioned Goniostat( Goniometer) designs of the Holzapffel Ornamental Turning Lathes into a more modern -and probably more acceptable format.
The fault( my opinion only) is that the newer design maintains ONE honed angle whereas the old design allows for alterations.
Just for the record, I bought a pack of these Chinese(?) diamond pastes in syringes to fine hone some of my lathe tools using a bit of plate glass on a sand tray. I used a bit of olive oil as a sort of thinner.
My half and half trick which somewhere between the Goniostat and the tool and cutter grinder is a undrilled chuck plate on the lathe- with the abrasive on the outer edge of the chuck plate.
Whatever your choice, you do get some beautiful turning.
Thank you for raising the information
Norman
Those look to be excellent holders. I too agree that yours look better than the commercial one.
Are drawings available anywhere for these?
Tom
Sorry, no drawings Tom, I just machined mine as I went along. You just need to make it a suitable size for your lathe though and ensure the bit is tipped 12 degrees forward and 12 to the left.
Hello Omnimil
12 degree entry or whatever angle is to much.Carbide inserts use 7 degree and 8 to 9 degree is just managable for tangential holders.
12 degrees works fine, do a google and you'll find dozens of folks are using holders like these and making some good stuff with them. Not sure why you mention carbide inserts, these use pieces of HSS.
http://www.gadgetbuilder.com/ToolHolders.html#Tangent
http://mikesworkshop.weebly.com/tangential-tool-holder.html
http://www.metalworkingfun.com/showthread.php?tid=1923
http://www.homemodelenginemachinist.com/f13/my-take-tangential-tool-holder-14133/
http://madmodder.net/index.php/topic,8910.msg97331.html#msg97331
http://www.homemodelenginemachinist.com/f13/my-tangential-toolholder-17462/
http://www.homemodelenginemachinist.com/f43/tangential-diamond-tool-holders-14673/
Construction of this type of tool holder is also nicely documented on pages 12-14 of issue number 156 of Model Engineers Workshop if you can get hold of it.
Thanks for the links they were very helpful lots of information!!
Hello Omnimill
12 degree entry angles works fine as You mention, but so do 8 and tool will keep sharpness longer.
What is the correct anglo-saxon word for this 12 or 8 degree angle?
Glad to be of help. I didn't document the construction of mine but some of the folks in the links did which is very useful if you've not made one before.
They are very easy to make if you have a tilt and swivel vice on the mill. Simply rough out the tool with the vice in its normal position then swing the vice round 12 degrees and tip it up 12 degrees to cut the slot and drill the clamp hole.
Couple more links.
http://bbs.homeshopmachinist.net/threads/59374-Tangential-toolholders-evovling-in-my-shop
http://www.projectsinmetal.com/forum/general-discussion/my-favorite-lathe-tool/
http://chaski.org/homemachinist/viewtopic.php?f=4&t=89950
http://www.homeshopmachinist.net/passblast/hsm/hsmdec08.html
This is the new (to me) commercial holder for mini lathes.
http://bay-com.com/machining__/site...DVDWeldingDVDmachinistbooks-35-1html-238.html
A picture of the sharpening jig in use. you can use a grinder instead, I just like the belt sander. The small black jig is the one that comes with the commercial tool.
[/URL]
I agree with all the comments from other members; a very useful & simple tool. I use mine for about 95% of my cutting, on all types of material (mainly steel / brass / aluminium). I originally bought mine from Eccentric Engineering (usual disclaimer) & although expensive initially ,well worth the money. I have now put a left handed version on my toduit list, for back facing (will attempt to make this one :rolleyes: )
George
