Quantcast
Succeed in the 3D CNC aluminium propeller milling
Help Support HMEM:
laurent_parti
Hi all,
Really appreciate all the support from many of you and I would not let this project stand alone.
I made some analysis and testings and I found a good solution, as the machine is different from a regular CNC Lol.
Would not let you miss the result of the top face CNC milling:
[ame]http://www.youtube.com/watch?v=bJOY3dwpX_w[/ame]
Laurent
jwcnc1911
-jwcnc191
Way to go Laurent! Now you got to work on surface finish and a jig to locate it so you can do the other side.
You're moving the right direction!
laurent_parti
Thanks JWCNC1911. I already created a jig it with 4 pins ( on my channel it is the part #3 of the propeller milling) and did the back side. Will post the video next week.
Regarding the surface finish, I did not have received the proper end mill at time and use a too small one.
Laurent
