Rocket Man
- Nov 4, 2011
- 240
- 121
1.5" bore 1.5" stroke. The black tank on the back is the electric boiler. I have a 250 watt 120 VAC heater in the 4" diameter boiler tank. It has a 125 psi pressure release. I have the main steam line wrapped with insulation material. The engine will run very slow about 20 RPM all day on 5 psi steam pressure. If I replace the flat belt pully you see on the front with a 24" fan blade the steam engine has no problem turning the blade at 500 RPMs.
http://s43.photobucket.com/user/gary350/media/SteamEngine_zps16d8da47.mp4.html?sort=3&o=0
