Starrett 174 dimensions
Heya
If any one has one would you mind filling in some of the measurements as show in the pic? I want to have a go at making one but want it to look right.
Just in case its hard to work out from the pic the measurements I need are:
A) Total length of the body
B) Distance from center of the hole to the short side
C) Length from the end of long side to the point where the taper finishes
D) Length of the middle section
E) Diameter of taper at smallest point
F) Diameter of taper at largest point
G) Diameter of knurled part of adjustment screw
H) Length Of knurled part of adjustment screw
Not labeled on drawing.
I) Diameter of center hole
J) Diameter of hole in adjustment screw
K) Total length of adjustment screw
L) Thickness of flat center section
M) Diameter of the center section
I would really appreciate your help with this one, could be a cool little project and if it works out alright ill draw up some plans and post them on here. I reckon it could make a good first or second project for people starting out
BTW I dont mind if you measure in metric or imperial but I would like it to be reasonably accurate if possible
Jonathan
Hello Jonathan,
I would suggest that you make the screw out of drill rod or silver steel for durability. You can file the square corner for the tap or broach it. I can give the details of the broach that is made from a broken #10 tap shank if interested. I also have process sheets and diagrams available if anyone is interested.
Mike
Here are a few photos of the tap wrench.
A 2.985"
B 1.127"
C 1.452"
D 0.582"
E 0.287"
F 0.334"
G 0.388"
H 0.595"
If you need more dimensions just say the word I have three of them
Mike thanks for that, is pretty much what im looking for but the dimensions seem a little different.
Dave could you measure these as well? I want to compare them to the drawings mike posted
J) Total length of adjustment screw
K) Thickness of flat center section
L) Diameter of the center section
I 0.25"
J 1.925
K 0.314
L 0.435
Additional just in case
M 0.152" through hole in adjustment screw
N 0.171" dia. On adjustment screw anvil.
David Hetrick.
The plans i drew up are attached, I did them really quick so theres probably some stuff wrong but i did have a go at making one.
It was done exactly to the drawings until i got to the hole in the handle which wandered off center, to bring it back i had to go through with a 7mm drill so it doesn't quite look right. One thing to note is the radius on the drawing is too small if you want to be super close to the original. But all in all I think it turned out alright, might have another go at some point.
View attachment body.PDF
View attachment screw.PDF
