There are several things you want to avoid when you shoot with BP.
Assuming the construction of the barrel is adequate and can hold the pressure involved and you know HOW to load and WHICH load you have to use for your projectile (even a to light load for your projectile weight can result in the explosion of your device)
Using a wrong type of blackpowder (grain size FG, FFG etc.) even the " correct amount" (given for your projectile weight, barrel length and weapon type) will inevitably cause you failure and sorrow.
1
Assuming the construction of the barrel is adequate and can hold the pressure involved after shooting you have to clean out the barrel. The chemical reaction of the explosion leaves among other things sulphuric acid and saltpeter behind which have to be removed. Any voids, cracks, clearances will be filled by explosion gasses and start to corrode IMMEDIATELY, weakening the material and thereby making it a time bomb each time you use it.
Cleaning BP rifle's, pistols, shotguns etc. is generally done by mixing some detergent with hot water. After the water stops discoloring the barrel is rinsed with plain hot water removing all left over detergents. The water also wants to fill voids etc. and start corrosion the same as the gasses would. So the barrel must be completely free from all moist and gas residue after which a good gun oil is used to prevent corrosion.
2
In case of a misfire (charge will not go off) you have got a serious problem. BP is friction sensitive, highly instable, hygroscopic and very easy to set off (but just not in this case when you want it to be). EG poking a stick with a screw on top (non ferrous) to remove whatever obstruction (bullet, wads, cardboard) is in the barrel is what it normally takes to let the screw "bite" the obstruction. And could set of your charge whilst holding on to the stick, and yes I've seen it all happen.
The bigger the bore the more difficult it is to remove the charge because of the force it takes to remove the obstruction.
Making a screw-in breech eliminates most of the danger if great care is taken in making sure the BP can NEVER EVER get in between the threads (friction sensitive)
3
The bore should be even and smooth along the entire barrel, a hiccup of some sort will lead to peak pressures and the possible destruction of your barrel. DOM is the material to go by for this (and the material strength is uniform of course) (also chokes on shotguns are an exception when your load and design match)
If you want a bang, you have to make sure there's a real snug fit or there will be no pressure buildup. This generally makes it just as lethal as a normal bullet would. Difference being that because there is less weight involved in the projectile it loses energy quite fast and the reach is less as a result.
EDIT: perhaps I have to add a disclaimer to everything I say for it is never complete and there could be mistakes as English isn't my mother tongue and I sadly do not have all wisdom
1
2
3
