- Jul 16, 2007
- 2,985
- 1,052
Here's a follow up to the small globe valve thread. As I had mentioned I have been using a manifold with aquarium type valves on it to distribute compressed air to my models when I exhibit them. It worked ok. but just didn't fit the part so I started on this project. I wanted something industrial looking to fit my engines. I started with a piece of .625 brass tubing for the manifold. I then made up the valve bosses along with the internal sleeves to locate them to the manifold when soldering. I then made the end caps and decided to put 0-80 bolts into them to make them look like a high pressure pipe cap. Next I tried to figure the best way to make the legs. I could cut them out of a piece of flat brass stock, solder them to another piece of stock, set them up on my rotary table and whittle them down or I could machine them onto the end of a piece of 2.00 round stock that I had and then saw them off in the mill. The second option seemed like less work so that is how the legs got made. The manifold was then drilled for the bushing size, everything was assembled and fluxed and then soft soldered together with 50/50 solder. After soldering I cleaned everything up with an old toothbrush and powdered copper cleaner, the type for cleaning copper pots and pans. The valves were then installed and shims were made to get them all properly lined up. All I have to do now is make the spigots for the air lines to slip over.
gbritnell
gbritnell
