Milton,
I noticed that when I cut at slow speed the chips would wedge between the blade and slot and stall the blade. I then upped
the speed to between 800 and 1000 RPM, it was just fine when the smoke started to show, no problem then. After that I checked the
teeth with a magnifier Glass and they are all fine.
As cutting fluid, I used the blackbrown stuff in the blue can, also from HD out in the plumbing section. I put on two or three strokes per cut, on the top and bottom with an Acid Brush.
I did not see the 24 tooth blade. I may work even better.
Hilmar
