Thanks Dave, You'll have some mail in a while.
I found this particular "FORMULA" more my speed. No strange martian writting involved, unless you count the pi thingy for circular mathematics
Here is what I came up with
BORE 1 inch
RADIUS .5 inch
AREA .785 sq in
RUNS@ 400 RPM
TIMES 5 (2.5 inch stroke x 2 directions)
EQUALS 2000 inch per minute Piston Speed
DIV by 12 inches in a foot
EQUALS 166.67 feet per minute Piston Speed
The area of my piston (times) the speed of the piston
Should equal
The area of my port (times) The speed of steam through Port
Given the books suggestion for a speed of 4000 to 5000 feet per minute and knowing that the steams speed is greater the greater the pressure of the steam, I shall aim for a "safe" speed of 2500 feet per minute.
That gives me three of the four parts. SO I should be able to select a proper opening size in square inches. ACCORDING TO THE BOOK. I'm only trying to verify or disprove or otherwise investigate the words found in the book and not giving out design criteria.
Disclaimer being done with; let's crunch them numbers, shall we?
.785 x 166.67= 130.84
Then
130.84 = area of my steam port x 2500 - selected speed of steam
130.84 / 2500 =.05234 sq in
.05234 = 3.141 x r x r
.01667 = r sq
.1291 inches = radius of Port.
Hmmmm. Sounds small but I was thinking of 1/8 holes for the steam(two of them actually). That is what I would have gotten with 5000 instead of 2500 as the Author suggested. THIS MEANS my first guess of two 1/8 inch holes for the steam WAS RIGHT.
Somethings GOTTA BE wrong 8)
Kermit
