How much aluminum shrinks is not really what you are after, but what you need to know is how much bigger you need to make your pattern.
For the particular alloy of aluminum that I use (356), if you want to make a piece that is 12" long, then the pattern needs to be (12*1.02) = 12.24" long.
You can fine tune your multiplier by cutting a 1/4" square piece of wood to 12.24" length, casting it, and then comparing it to 12".
When casting AL 356, 1.02 is pretty much on the money, but other alloys may vary, but you can easily find out the multiplier for any alloy, as noted above.
Another method that has worked well for me is to plot out a CAD drawing using a 1.02 multiplier (for AL), glue the CAD drawing to the block of wood, and then carve out the pattern. A shrinkage rule is not required.
If you really want a shrinkage rule, just draw a standard 12" ruler in CAD, and then plot it to whatever multiplier is required for the various metals. You can print it on card stock and then laminate it in plastic. Works fine.
