I'm getting shiny bands on work when I am turning under power feed on a Myford Super 7. The bands are I guess about 20 thou wide and at regular 1/8 inch spacing. They are cut into the work by an amount unmeasurable with my equipment but are the last things to vanish when I lap the OD.
Because the spacing is 1/8 inch and the Myford leadscrew is 8 TPI I think they are related and am guessing a bent leadscrew but would welcome all suggestions on other possible causes and cure.
The reason I suspect a bent lead screw is because the lathe was stolen a while ago by Peter Underhay a burglar so amazingly incompetent that when I recovered it he had set the motor on fire, destroyed the Dewhurst switch and bent both the front bracket on the cross slide and the cross feed screw, the Allen screws holding the front bracket on the cross slide were slacked off 2 turns so the cross feed screw could be turned at all.
Richard
Richard
