Rod Gland Material
As I progress through building the Corliss, it is time for me to find gland packing for the piston rod and the steam valves. Where has anyone found a supply of chevrons, or whatever they are called in steamers.
You can buy gland packing in various sizes, materials and configurations from McMaster Carr. Examples of what they carry are here:
http://www.mcmaster.com/#graphite-packing/=a8hfn5
I've used the graphite impregnated braided fiber successfully. For the scale I'm working at, I undo the braids and wrap single strands around the piston rod.
Phil
I use leather. When I was a teen my Dad gave me a leather tooling set. I've been stuck on it ever sense. I used leather washers punched out of vegetable tanned leather about 1/8" thick in a full size Creaters Popcorn engine I built in the mid 80's after I got out of the Navy. I purchased the casting kit from Myers Engine Works.
http://www.myersengines.com/engines/popcorn_engine.htm
Graghite Packing can be obtained at the local Hardware Store. It is used to pack the stems on outdoor and indoor spiggots. You will find it in the Plumbing Dept. under that name, "Graphite Packing' This will work well for your application.
"Bill Gruby"
Viton O-rings.... at least for saturated steam, work very well.
When I built my Corliss, I have some 1/8" packing which is way too big. The way i solved the problem was to cut off the lengths I needed, and then carefully un brade the packing and then twist the strands together until I got a size I could use.
