Tony Bird
Senior Member
- Feb 20, 2011
- 798
- 847
Hi,
Thanks to a friend I am the proud possessor of the parts of an old fairly large model vertical steam engine.
The following photographs were taken of the engine being taken apart to assess its condition and what will have to be done to the existing parts before work is started on making the missing parts. As will be seen unfortunately isn't very well made.
As perhaps can be seen from the photographs the casting are very good but alas the machining of them not so. The valve fitting the steam chest is all that is left of the regulator that would have been operated by a governor, there is what might have been used as a drain cock in the top of the cylinders and the piston has a piston ring.
All the parts of the engine have been cleaned. First the parts were washed in paraffin, then washed in soapy water, and then boiled for 10 minutes or so in washing soda. Then brass parts were then scrubbed with wire wool and soap in warm water. The rusty steel parts were put in a caustic soda/water solution which loosens and removes the rust before resorting to the wire wool and soap. The larger screws and nuts having been cleaned were oil blackened, because of the rusting the very small screws will have to be replaced. The result of the cleaning.
Boiling in washing soda best done with your own pan when the domestic authorities are away.
Just out of the pan.
The cleaning helps in the removal of fixings.
After the wire wool and soap treatment.
The remainder of parts treated.
The small screws that will have to be replaced.
A plugged hole in the crank.
As can be seen from the photographs it isn't very well made. However given that it was possibly made by an amateur using probably a treadle lathe, a hand powered drill a hand shaping machine all using carbon tools. The most used tool probably being the file and all being done in indifferent lighting maybe it isn't so bad?
Because it is so out of square it has been mounted on a flat board to show where problems are.
Getting the axle over a centre line.
Centring the engine over the axle.
A bit of an issue with the cross head and the piston rod.
A little out of vertical.
Leaning a bit?
Not quite square?
A little bit out?
So far it has taken about a day and a half to get this far; I suspect it will take some time before I decide how to progress with the restoration. The new parts needed, will have to be researched. Correcting the lining up of components without too much re- engineering will be interesting. If anyone has photographs/drawings of a similar old engine which would be helpful. Though the engine came to me from Germany the screws are BSW and BSF the bore is 1.3/8" and the stroke 1.5" so it is likely made in the UK. If anyone has an unwanted 9" flywheel???
Regards Tony.
Leaning a bit?
Not quite square?
A little bit out?
Regards Tony.
