I have yet to do dovetails, but its coming one day. When you say 'too heavy', about how much were you advancing the dovetail cutter when bad things happened?
Well done Gus, now you can go fishing
Pat
Gus:
I have a variety of HSS tooling. And I have no doubt that the USA Swedish UK steel is superior.
I have heard many negatives on Chinese HSS.
IIRC the import ones I buy from enco are from India. but I do have a box of 1/4 Chinese blanks that I have ground and used. They work fine on aluminum and brass. and probably ok on 12L14 steel.
My Chinese insert tools are junk I have set them aside(Horible Fright Brand)
I will say if you can afford the tools the AR Warner tools from Latrobe PA are fantastic.
http://www.arwarnerco.com/c-12-turning.aspx I have talked to the owner several times. I have 3 of his sets and I have yet to need to replace an insert.
part of cutting tool performance is the metallurgy you can not get away from that.
part of it is how the tool is sharpened. if you overheat the tool you can reduce performance. Tool geometry is important. every material has a best set of angles. the better the grind the better the performance. hone the tool. it helps a lot.
Speeds and feeds drastically effect tool life. Use the correct ones for the job.
Hi Gus,
It is better if they didn't change color but provided the steel is a good one a bit of discoloration should not do them any harm, hope you didn't mind me replying. I use a belt sander in preference to a grinder and I find that it works cooler and I don't need to quench the tool so often. And well done with the tool post, looks very good.
A.G
