I had to align two disks for a crank shaft so I could press in the crank pin. The 1/2 shafts get pressed in next. I didn't have a shaft to put through the center hole to hold the two disks on the same center. Then I thought of using 3 rods. I played around with rods from my index of drill rods until I found 3 that just fit (slight push) (using 3 is important,) I think you could get just about any size by playing with combinations of rods.
Frank
Frank
