Poppin Hoglet Display
kcmillin
After completing the V-Tiwn flame eater engine I decided it needed a good home.
Started by making the frame. Soldered together CRS.
and with the engine in place...
Thats it for know.
I need to learn how to do miniature sheet metal work for the fenders and gas tank.
Kel
here is another pic for proportion. With the tire and a rod to show the rake.
Still need to make the tranny, and figure out if I want to use a chain, or a belt.
kel
I like that idea Kel.
Flames at the cylinders instead of popping out the exhaust pipes.. scratch.gif
Oh Yeah. Works for me! Thm:
Now you need to build a tiny English Wheel for the sheet metal work.
I'm sure that has been done before, but I can't come up with a reference
to it. Maybe someone else here can.
Rick
Thanks Rick, this puts a hole new meaning to flames on a motorcycle.
I have never done any english wheel work before, I might just wing it, using a hammer and whatnot. I plan on using .030" brass, but copper also crossed my mind.
Which material would be best, and how thick should it be?
Anyway, I needed to make a rim for the rear tire. The only material I had big enough was a 2.5" steel round bar. A little overkill for the purpose, but it will do.
I hope it acts as a flywheel. The motor I made does not require a flywheel to run, and should have enough power to turn this wheel. But I guess I will find out.
here are the pics.
the rear axel.
For the tire I used an RC truck tire. 4" round by 2" wide.
I did not like the tread so I sanded it off with the belt sander (a tool I use constantly)
As a bonus, sanding the rubber tire cleaned the belt on the sander very well.
Thats it for now. I still have not decided to put spokes in the wheel or not, there wont be much room once I make the hub.
kel
I've been watching kel and it's looking good.
I'll be interested in seeing your sheet metal work.
Got a few more bits done today.
The hub for the rear wheel, with a pully.
Now on to the tranny bit.
sheetmetal soon.
kel
Started work on the tranny case. This will just be a simple single shaft. Nothing fancy. Two caps and a case.
started with 2 inch aluminum and bored a .8" hole and made 3 sides flat.
More to come
Got some more work done on the tranny today.
There will be a simple clutch so I can disengage the rear wheel.
Milling out the inside of the case so I can have room to make the clutch.
Here is the engine input side, just a simple pully on the outside, and a brass "clutch" plate on th inside.
Milling the 1/8" keyway for the clutch to ride on.
Broaching the keyslot in the moving side of the clutch.
here it is installed for friction and running testing.
Thats it for today.
hope to figure out the linkage for the clutch tomorow.
Kel
Pretty cool stuff you're doing here, Kel. The rim for that rear tire turned out rather spectacular. Very nice.
I like your idea for the clutch, too. That might be a neat one to draw up for the forum downloads section.
Dean
Got some more of the clutch bits done today. Ill try to draw up some plans for this, all my dimentions are specific to this but can be used for a variety of applications.
The clutch plates are both brass, this is so they will slip easy but still grab to turn the wheel.
here is the clutch closed.
here is the clutch open.
Clutch fork, I cut off half the fork to decrease friction, the clutch only needs to move .010, so this will do.
Linkage for clutch fork
assembled tranny.
here are pics off where I am in the build.
mockup with front tire.
Video of clutch in action.
Thats it for today.
Kel
Very very nice Kel. I didn't realize it was as big as it is. thought it was smaller.
Keep up the good work.
Ron
Thanks for replying Ozzie (and everyone)
The proportions are turning out to be a little cartoonish, with the big engine and all. I wanted to make it smaller but it just would have ended up too goofy lookin.
This started out being just a display for my popping hog motor, but its turning out to be an even bigger project than I had imagined.
I hate to dissapoint anybody, but I have zero sheet metal experience, aside from bending flat angles in a brake. (I am a sider by trade, and using a brake is a weekly thing)
So.. I am probobly going to go with a sharp angle style fender, and gas tank.
I would like to make the gas tank functional, but I have concerns about filling a tank full of alchohol, and then starting a fire underneath it.
Kel
Your clutch looks like it works great. There could be a lot of applications for that.
I don't know how you're equipped there, Kel, but KustomKB has a pretty good bit of info about bending and hammering sheet into shapes on his Hoglett thread. You've got some experience already. Maybe you'll see something there that gives you some ideas.
...but I have concerns about filling a tank full of alchohol, and then starting a fire underneath it.
I reckon you're onto something there...
Dean
Awesome Kel.
And thanks for the pics on the clutch...I know next to nothing about them so I found that pretty helpful.
Hi Kel, with the way that choppers are built today I don't think it looks cartoonish at all. It would be neat to build something like that for my engine but I'm afraid it would shake itself apart. :big: :big:
gbritnell
Nice...an engine that really does something. :bow:
The rubber tire looks great. Have you considered making it out of something more lightweight though so it doesn't bog down the engine so much?
Waiting for the next update...
Looks and works great!
I'm hoping to sneak a little shop time in this weekend for my Hoglet.
I hear what you saying about the display becoming a project in itself...
Nice job!
Thanks for commenting guys.
Winklmj, The bog of the engine is something In was going for, its kinda fun to let the clutch out slow, just like the real deal. Too fast, and you will kill the engine.
kustomkb, I gotta admit, you project is an inspiration for mine. I hope you dont mind I borrowed the "Hoglet" name.
kel
got some more time today, Decided to get the front end done.
I figure a rigid frame would be even more badass with a rigid front end. Plus it will be eaiser to make. I was looking at making a springer but decided against it. I did not want it to get too busy.
the forks are made from steel with brass ends.
After soldering, it was put in the lathe for a taper to be turned onto it.
here is the triple tree parts
the assembly soldered together.
the front tire.
and installed on the bike.
thats it for know.
onto the handlebars.
Kel
Thanks Kel, I'm flattered. Randall Cox, the designer, coined the name though.
Really cracking it off eh?
Nice!
