Hey guys:
I have done a little painting on objects that can be held in your hand to 40 foot long boat patterns. And stuff in between. I was a painter for a shop that made models and training equipment for industry and colleges.Also trained as an aircraft painter. Most of my models are not painted .
first off all what finish are you looking for ?
the finished product will only be as smooth as the base metal .
here are some basics
the surface needs to be completely clean no metal chips no oil no oxidation. no finger prints.
use a sand-able primer if you want a fine finish
light bright colors such as yellow and orange show up much nicer with a white primer undercoat.
follow manufacturers recommendations
get the spray cans that give you a fan spray
make sure masking tape is tight to the surface for a clean line.
keep the spray can moving across the part.
look at the part and spray from as many angles as possible light coats.
A turntable helps but a coffee can you can turn helps or hang the part with a piece of wire coat hanger.
use proper ventilation.
when done invert can and spray air to clean nozzle.
My suggestion is get a can of white or gray sandable primer and a couple cans of paint from the local auto parts store.
If you have never painted before you may want to practice on a piece of scrap of similar size shape and material.
This model was done in 2003 and has held up fine it has run at least a couple of shows for the last 6 years. basic industrial enamel.
Hope this helps
