student123
- Oct 31, 2009
- 183
- 0
My novice build of the littlemachineshop oscillating engine continues
http://littlemachineshop.com/Projects/OscillatingEngine.php
piston brass,all else aluminium testing on compressed air, no long term plans for steam running. Here's a pic (prev posted) all assembled:
Having , with help from you guys, stopped air leaking through a gasket, things have progressed.
The cylinder moves slightly (maybe 5% of turn on the crank) but soon stops with air escaping between the cylinder & the upright.
Presumably I need to spend some time lapping the cyl to the upright?
I did spend a little time smoothing both surface with oiled wet & dry., but I did them separately.
Should I be rubbing them together with some toothpaste in between ??
if yes approx how long should it take (I understand t depends on the existing surface quality , but typically lap for 10 minutes ? an hour ?)
Or do I smooth each out surface separately with wet & dry?
Would a stronger pivot spring help?
I should add that occasionally , when turning the engine by hand , I get some resistance. Maybe 1 in 20 times. If I turn it back a little then go again things seem ok. I just mention that symptom in case it indicates a prob i haven't figured out yet.
Mike
Mike
