One for MKlotz - Calculate Cut of 90 Deg V
Help Support HMEM:
dwentz
OK I am working on a project and need to cut a 90 Degree V in a part .133 Deep.
I have the part to be machine set at a 45 Degree angle and have the corner of the mill set at the center line of the cut.
What I can not figure out is how deep and how for back do I need to move the part to get the correct depth of .133
I have done this before by trial and error, but it would be nice to get this one correct.
rkepler
What's the size of the square in there? I recall 3/16 and if I remember how I did it from that position I started with the edge dead on center, fed the Z 1/2 of the 3/16 and then fed the X (or Y) the other half. That should give you 2 faces each 3/16".
Not sure where the .133 came from...
maverick
Elizabeth, Colorado
For .133 depth ,the move is Y+.094 and Z-.094,
.094 is the base and height of a right triangle whose hypoteneuse is .133
bezalel2000
IIRC
multiply .133 x Sqr root of 2 then divide by 2
or .133 x 1.4142 / 2 = .094
z= down .094
x= .094
Bez
mklotz
You've already had several correct answers assuming that the 0.133 dimension is the depth of the V from the surface to the deepest point. Then the answer is simply:
0.133 * sin(45) and 0.133 * cos(45)
Since sin(45) = cos(45) = 0.5*sqrt(2) = 0.707...
the answer is 0.094 in both cases.
It's not always easy for the responders to visualize the details of a question like this. In the future a diagram will help to ensure correct answers.
dwentz
Thanks everyone, I looked in the machinery handbook but could not find it. I was going to sneak up on a layout line, which I had done in the past, but I wanted to know the correct way as I have run into this before.
Thanks again,
Dale
Group Builder
