So with a few parts (crank and flywheel) fairly complete its what are they for?
Leaning towards a Finger Engine, no plan, just winging it. Need some column type supports for the crank to ride in, a whole new adventure in itself. Decide that a bit of curvature to the otherwise straight side approach might look appealing, but how the heck..
I got a lathe. . . faceplate time. drew out the part and found the arc centerline, had to make some adjustments in the design to keep the part within the limits of the lathe. Ended on a 1 1/2 inch radius for max that would fit both the lathe and eye appeal. As the arc center line is offset from the parts center line, had to measure from the face plate center line to locate part. Once done a little block was attached to act as an index. Made a boring bar from an old 3/8" drill bit, clamped the material down in place and let er rip, slowly, painfully slow, the thought of a hunk of metal flying across the barn from the imbalance tempered the "Get er Done" motto.
I notice most clean up the process prior to snapping a photo, does help to illustrate but the actually view is surely messy.
Me thinks a mill could knock this type of part out with a lot less fanfare, we will see how the AA109 does on this task asked.
I think that plate has seen its better days. Time for another
