I was planning on making a fly cutter tonight and had specially bought myself a 1/4 reamer and ordered myself the material a few weeks back.
Got into the workshop and realised in my bulk order I had mistakenly ordered 3/8 BMS instead of 5/8 BMS.
So there went my plans to make a fly cutter tonight but I was in the workshop and still wanted to do something so I started on another simple tool that was lower down on my list but I had all the materials for it.
Although this is from my books of tools for clock makers I can see it being handy for other people too.
Let see if someone can guess what it will be before I finish it.
Start off with a 16mm bolt
Cut the head off and machine the shaft and nut square.
Cut a cap for the nut out of 1/16 mild steel.
Glue it to the nut, file it to size and then drill it for 10BA screws.
Remove the MS cap of the nut, clearance drill the cap, countersink the nut and then tap for 10BA
This is as far as I got tonight I should hopefully finish it tomorrow.
