fcheslop
I have a problem with my old ML7 and wonder if anybody has had the same. When drilling deep holes in small diameters the hole never drills true always comes out to one side and if the hole is very deep it can come out of the side of the job sorry if I'm not being very clear.The machine has recently had new bearings and mandrel fitted but the problem existed before and has not improved.Have set the machine up with a test bar between centres and clocked in using a test bare fitted into the headstock it will turn true and bore true but Will not drill true.I know I'm probably missing something simple but cant find it .The tailstock has been stripped and no burrs or any problems found in the casting or barrel.Its always done this since i purchased it but is now becoming a problem due to wanting to make ever smaller parts. The machine is mounted on a sturdy wooden bench that does tend to move with the change in humidity but I always set it up for doing accurate work and can turn 14 inches to within a couple of tenths 0.002 and bore to the same accuracy or as near as i can read my mikes scale.I withdraw the drill often when drilling but some times i think i see the drill bit dipping as it starts the smaller the dia the worse the problem I've also used different drill chucks?.My test bares where made on precision centre grinders and if i test between centres on the lathe there is no radial run out either at the head stock or tailstock Istill think it is something simple I'm missing but now have no hair left to pull out.Any help would be appreciated.
regards Frazer
regards Frazer
