On Elmer's plans, the transfer of air/steam is accomplished using a copper tube between the valve/bearing block and the cylinder. My modification eliminates the bending and soldering required by Elmers original plans. I decided to use 3/16" model pipe connecting the cylinder and bearing block. Although there are other ways to accomplish the connection, I decided to use a simple adjustable union. I made round unions in the past that worked well on other builds. Then the idea of continuing the hexagonal theme by incorporating it in the design of the union came to mind.
The picture below shows one half of the union being cut off on the lathe after the first machining steps were completed.
I used a larger piece of a hex with a central spigot tapped 10-40 to index the parts during the drilling and tapping. Since the parts themselves are a hex their mounting needed to be parallel with the indexing block. To line up the parts with the block, a parallel was held against the part while it was rotated into position lining it up with the front jaw on the vise. Blue Locktite was used to eliminate the possibility of the part moving. This line up method proved simple and effective.
To eliminate the possibility of the tap breaking, the drill chuck was held very slightly open to guide the tap. I used what I call a "Tapping Disc" (knurled aluminum disc with a set screw to hold the tap) to the rotate the tap. I have not yet broken a tap using one of these discs. I have snapped plenty of 4-40 taps using a tap wrench or by jogging the power switch. You would think one would have been enough! ;D
The photo below shows one union half being drilled prior to tapping.
The other half was clearance drilled for the screws.
I usually rough draw a part and attach it with a magnet to the machine I'm using. Later when the part is finished the drawing goes in the rubbish. After a few days I can't understand my own gibberish anyway! I hope someone out there can understand the picture below.
EDIT: The diameter of a round union should be .575" using the bolt spread and the spigot diameter in my drawing. The older round union is a smaller bolt circle with a very thin threaded spigot wall.
4) This last shot shows an earlier round union and the two hex unions I made today. This build requires only one union, I got carried away and made two.
I should have filed and sanded the stock prior to machining. After cleaning up one union (shown in pic) my fingers said... no more!
-MB
