Chads, the 'Webster' IC engine uses a small off the shelf carb. They are very simple to make, vs buying carbs that are expensive.
Randal, a hit-n- miss engine needs a carburator with an adjustment needle. The needle is Not used like a throttle to set the speed. The needle it used to adjust the flow of fuel, to get the proper air to fuel mixture (ratio). Not enough fuel and the engine stall, to much fuel and the engine stalls.
The engine speed is controlled by the exhaust valve lock out mechanism, which is controlled by centrifugal governor weights, which are controlled by variable spring tension.
Speed controlled by speed. :idea:
-MB
