Having the carb higher than the carb is definitly a no no on this type of engine where there is no float and needle to shut off the flow of gasoline automatically. I learned that by bitter experience while trying to get my Kerzel engine to run. It would do the same as yours. Start, run good for about 30 deconds then die out. Once I dropped the tank so that when full the top of the fuel was at about the center of the carb height, it fixed my problem. Gas does run down hill, and floods your engine. There is enough vacuum created by the venturi effect in the carb to pull the gas up a bit to the level of the needle valve.---Brian
