Hi Picclock,
Your little problem has dragged me out from lurking and made me register as a member!
I believe you will find joy with shrink fitting as Bezalel has mentioned, but go in the reverse direction.
Machine the slots to size, then make the plates oversize(or whatever is easiest)
Throw the lot in the freezer for ?? time and all the metal will shrink. Your slots will get wider, the plates narrower.
Assemble the lot and as the Ali warms back up to room temperature, the slots will narrow and the plates widen.. they will be firmly attached, you will be surprised how strong this is, particularly with the surface area you will have in contact.
I have used this method to shrink fit many items over the years and it works a treat.
The thermal coefficient of expansion for Aluminium is 22.2^-6 M/M/degC, or, 12.3^-6 in/in/degF
Hope you give it a shot
Edit: Hmmm, the thicknesses of material you are working with may be a problem.
Play with this (very)rough spreadsheet I threw together and see what you think.
That shrink figure is for one item only... the slot or the sheet.. combine the two.
(rename the file from Therm.txt to Therm.xlsx)
View attachment Therm.txt
