mechanical lubricator
colin
Active Member
Hi all, does anybody have a design on a mechanical lubricator using the clutch type bearings not the ratchet type?:rolleyes:
Thanks Colin..
i wonder if the back slip would require to fast an oil delivery rate or if you would just go for a smaller pump piston
Would it not be possible to just substitute a miniature sprag clutch in place of the ratchet? You might have to experiment with the angular movement to get the clutch to grip which may be more or less than the ratchet method.
The Emerald Isle
the ratchet does have that old- time thing going for it . I had some trouble with the out put valve on the one I built . the design that works best for me used an o ring for sealing
