- Jul 16, 2007
- 2,986
- 1,055
What is an acceptable machining tolerance for model building? The short answer is it depends on what you're making. If it's something that requires a close tolerance, shaft fit, cylinder bore square or cylindricity, wrist pin fit or such then you make it fit like it should. If you're making a connecting rod and you machine the profile (outside shape and it's withing .005) what difference will it make. Now the main journal bore and the spacing between the bore and wrist pin hole that should be held to print although if the center to center distance varied by .002 who's going to know and it will never affect performance. The next variable that comes into play is the size or scale of what you're building. The smaller the model the closer you have to hit the numbers, .002 on something that's 3.00 diameter and .002 on something .300 diameter make a big difference in fit. Some builders will scrap a part if they don't hit a number right on the head. That's the level that they work to and are happy with. Most home shop tools, lathes and mills, depending on quality are capable of .0005 that is if the user knows the machine and how it cuts. Here again side cutting with an end mill will only get you so close. Try taking .0005 from the side of a block of steel in the mill.
The next variable is what kind of measuring tools are we using to establish size, digital calipers versus digital micrometers, telescoping gauges compared to bore gauges.
What is done in a high tech shop with millions of dollars of tooling isn't quite the same as what is being done is someones basement or garage.
The bottom line is strive for the best you can do and learn what dimensions are needed and what aren't.
gbritnell
gbritnell
