m8 left handed taps
krv3000
HI can any one lend me a set of m8 x1 pich left handed taps
HI jasonb thanks for the link but its left handed that i need not right handed ones the chepest ones that i have fawnd so far for a set is £49 + vat
Read what I said, Tracy only show the RH but in green it says "All taps available in larger sizes, H.S.S./GT, Spiral Point/Flute + Long Series, Also DIENUTS + L/H. Please call" Their L/H are typically twice the cost of R/H
The J&L ones are also L/H if you look at the bottom of the page, £11.91 +VAT ea
J
L 49 for a Tap?? In USD a Hertel is $25, others cheaper. That being a M8 x 1.0 LH. now are you looking for a 3 piece set? Taper, plug, bot., seems a bit much for a few holes.
I have a M8 x1.25 LH, postage to/fr UK may equal cost.
HI all thanks for the replays yep it needs to be metric its for my Cross slide of my compact 8 the feed nut on mine is broken yep i no i can by a new one but its made out of aluminum and i want to mack one out of bronze which to me is a much beater than the aluminum one yes i no i can by a set of taps but as I'm go wing to yous the taps ones don't want to by sumthing that will get used ones and never see daylight a gain thanks all for your help
Wouldn't that be a L/H "Acme" Metric thread then?
Pete
HI pete no its not a acme thread i will post sum pics soon
Will this work for you?
http://bbs.homeshopmachinist.net/showthread.php?t=43645&highlight=acetal+nuts
I've never tried it but may need to for the one piece nut on my Exe 2-1/2" lathe.
Looks like it offers near zero backlash and you can make a couple of spares while you're at it.
Like the man says you have to find a method of holding the 2 halves together when they're in service but the heat will do for you to shape the outside.
Ray
HI ray thanks for the link I have bit the bullet and ordered a set of taps from tracytools thanks every one for their help
KRV,
If I remember correctly your lathe is a Emco compact 8 isn't it? I find it hard to believe that Emco would use a standard thread form and not Acme. Did someone replace that screw and nut at some time? If your again having to replace it then maybe going back to the Acme thread would save you further work in the future.
Pete
HI pete yep my lathe is a compact 8 it dates from the 1970 and as far as i can see the parts are the origanal ones when I'm up on my feet i will post sum pics I have started to cut out the ruff shape of the new nut out of bronze bare I will post pics of the billed regards bob
Emco made the Unimat DB & SL machines with M8 LH leadscrews running in cast iron and ali. Most existing SLs have their original screws it seems, so Emco stuck with it.
KRV said his nut was broken, not worn, so I suppose Emco had intended it to be replaceable. Shame about the price :)
Ray
right the right pics
