dreeves said:
Hi Dave; I have a "Sieg KX1-NU" that I got on clearance from Novakon. It came *without* controller, so I had to get a Gecko 540 and power supply, and wire it myself; no problems there. I have a KX1 with *great* controller for a lot less than a turnkey one.
Ok - I'm getting used to this machine. First thing I made was an ER-16 collet holder, and got a collet set plus "smaller ER-collet nut". I got these from Maritool; more expensive than some suppliers, but I like supporting North American suppliers as much as I can. (I'm living in Canada). The collets are great; as to be expected from Maritool.
Second thing I did was configure it using EMC2 on a linux computer. I have a "joypad" used as a pendant; the whole system works incredibly well.
While the drawbar has an extractor, so far in my limited use, I have only had to change the ER collets - simplicity in itself, and much faster than changing an MT2 or R8 collet.
I'm still learning how to best use the machine; it has strengths and weaknesses; it is much smaller than my manual mill, for instance. Spindle speeds - it really moves; I'm getting used to this from my older mill that has a low speed range.
If you, or anyone else, goes for the remaining clearance KX1 from Novakon, and wants the notes I used, please send a private email, and I'll get them to you; the only tricky bits were rewiring the estop/spindle guard to be in series rather than parallel (holds signal low, rather than either one pulling signal high), and the spindle - I used the isolated power supply on the spindle board which entailed moving a screwed in connector on it, and adjusting a potentiometer on it.
JohnS.
