Hello All and hope you are all looking forward to the festive season.
I have two questions which I will address separately on different threads.
I need to cut a left hand internal thread for a nut in brass, size 12 x 1.75 mm pitch. just 4 threads needed. This will be cut on a Hercus ATM 260 lathe which has a threaded spindle i e not lockable. (similar to southbend)
The easier method is to run the lathe in reverse and start the thread from the right hand end and cut towards the chuck. (Threading tool facing away fron the operator)
How do I prevent the chuck from unwinding if the cut I am taking is too deep? Or do I go to the more awkward method of starting from the left hand end where the tool tip is not visible and run the lathe forwards (threading tool facing towards the operator) Your help appreciated.
Cheers Phil
Cheers Phil
