Just Got my hands on a Weslo Cadence 4350 Treadmill!. Well I started taking it apart and the motor was bigger than any treadmill motor I have seen. It is as big as the AC motor on my lathe now. I was disapointed that it is only rated at 1HP but my lathe motor is only rated at 3/4HP so i'll try this one just to see.
When it came time to measure and figure out how to mount this motor I found out this is almost a direct replacement ;D The mounting plate has the same hole spacing, the shaft length mesured from the mounting hole is the same, and The shaft hight from the mounting plate is the same. All I need to do is machine 36mm of the shaft down to 14mm and bolt it up. Then build a shield to keep the chips out.
Should get this together in a few days and will post more pics.
I have a plan on using start and stop buttons on the original treadmill speed controller so I don't have to readjust the speed after every stop. I'll put another pot in line with the speed pot between the low side and adjust it so when the speed pot is all the way down it will not be off just very slow. To stop it the Stop button is connected where the treadmill key was that shuts it down if you fall. To restart it I will have the start button connected between the W terminal and the L terminal pulling the speed signal low when pressed making the controller think you turned the speed dial all the way down and when you let up on the button the lathe will run at the speed the pot was set at. Will post pics of this to when I get at this point.
Jasen
Jasen
