Mechanicboy
- Jul 10, 2013
- 957
- 345
See the next message..
The arm that goes to the eccentric rod does not need to be slotted, so if you do alter them bear that in mind. All the arms should be able to be set without needing to run the engine so set them up, mark where the grub screw touches the shaft when in the right position and mill/file a flat for the screw to bear against. Make sure you set both sides to the same angle, ideally I would have the arms at 180degrees which would mean drilling another hole in the eccentric rod. This could be where you are loosing movement.
In an engine with reversing gear you can 'notch up', to shorten the cut-off point and so make better use of the expansion of the steam. The reversing gear alters the timing, but with conventional slide valves that inevityably results in a reduced stroke of the valve. Your valves are opening the ports far enough for perfectly satisfactory running (if properly timed), especially with no load. I think we need to start look elsewhere. Some of the things you have said so far lead me to wonder about friction.Here is an Interesting question. If the slide valve is positioned properly but the stroke is 30% short how would the cylinder react?
Just had a quick look at the renderings and think I have spotted what the problem may be. They show the arms that connect to the eccentric rods sticking up not down as you have them.
Moving them upwards will solve two issues
1. They will be in line with the arm that goes to the valve rod so no loss of movement due to the angular alignment you have at the moment
2. I said the eccentric rods would need shortening to get things in a straight line but as they need to reach a further distance with the arms at the top the length should now be OK.
