Quantcast
Imperial R8 Collet sets
Help Support HMEM:
Kpar
Kpar
GLADSTONE QLD Aust.
When I purchased my mill last year it came with all metric end mills & collets.
I now need to get some imperial R8 Collets. No problem getting imperial end mills locally but not the R8 Collets.
Can somebody suggest an Australian supplier.
Kpar
django
Active Member
You don't need to buy another set of collets because your metric set should cover all sizes through the range ie. 1-2mm, 2-3mm, 3-4mm, 4-5mm, etc, etc, up to whatever is your largest size is (mine is 20mm) therefor you have all imperial sizes up to 3/4" covered.
DJP
I'm not sure this is true as the collets need to be ER (Extended Range) to cover metric and imperial. R8 collets are size specific in my experience.
The good news is that R8 collets should be easily available on the used market as most guys switch to ER.
john_reese
I use an ER32 x R8 collet chuck most of the time. It covers both metric and imperial sizes within its capacity.
Kpar
Kpar
GLADSTONE QLD Aust.
Thanks all I will follow up on suggestions. Yes I did find imperial will not fit R8 collets so maybe getting a set of ER's is an option.
Kpar
kvom
Staff member
Kpar
Not sure what this means. My mill is R8 and I work with imperial stock all the time. These collets can hold several thou smaller, but should not be used with anything larger than the stated size.
ruzzie
#3 got their ER & R8 mixed up
Blogwitch
Ex Bogstandard
HMEM Supporter
Crewe, Cheshire, UK
Kpar,
Before you go searching out a set of ER collets.
I made the same mistake many years ago. I invariably now use metric and imperial spindle collets since then. ER's have a fatal flaw when used on fairly small milling machines, even though mine is a small Bridgy clone, you lose too much throat depth (around 2" to 3"), this can sometimes mean you just can't do the job as you can't regain that throat depth. Spindle collets allow the maximum you can get under the end of your spindle mounted cutter.
I found that the two sets of spindle collets (met & Imp) came to the same price as a good set of ER 32 ones.
Don't get me wrong, I still use the ER system (3 different size systems), but mainly on my lathe or table mounted tooling, but never for holding cutters in the mill.
DJP
Agreed that spindle collets save space but for my J Head mill an ER set would be nice for 90% of my needs. The R8 spindle collets force me to reach high to brake and release the collet and although the extra stretching exercise may seem like a bonus, it's not. I now have a small platform to make this task easier.
This is maybe getting off topic but the best solution would be an ER set plus a spindle set of collets in every dimension available.
bazmak
BAZMAK
HMEM Supporter
I have found that the R8/er32 collet set does everything i want
I also bought a few R8 collets that i use when i have height restrictions
