vcutajar
- Nov 6, 2011
- 863
- 169
Good day all
I am at the moment building the Westbury's Kiwi Mk2 engine and have a build log running in another part of this forum. I have finished the crank and now working on the bronze counterweights which will be bolted to the crank webs.
The holes in the crank webs (see photo) will be drilled 3mm clearance and possibly counterbored 5.5mm or 6mm. I do not have a problem drilling the 3mm holes by using a long drill but the counterbore I can't figure out how to do it. As you can see in the photo, the crank will be held in the vise upright for drilling and counterboring, but the shaft is more than 2" long. I have a 3mm counterbore which might be long enough for the job but that would increase the 3mm clearance hole to 3.2mm which I would like to avoid for this job. I thought about using a long 6mm endmill that I have which just might make it but would need to be held by the tip of the shank only so not very safe. Another option I am thinking about is using a drill and grinding the tip flat, but I have never done this and do not know what would be the end result.
So the question is, is there a simpler way of doing the counterbore that I am missing? Thanks for your patience in reading this long post.
Vince
Vince
