Hi all
busy doing research for an ignition system to put on a v8 engine that i want to make, but getting a little confused with how everything works and so forth.
hopefully someone can help me out, but my understanding is that, you have a coil to change the input voltage to the high voltage required for the spark. thats connected to the center of the distributor, which is connected to a spindle in the center which will rotate and touch the specific contact point and send a spark to the relative plug?
Cam
Cam
