Thats the self cleaning function of the points (and, incidentally, relay contacs), tiny amount of spark wipes out the oxidation, too big of a spark and the current wont collapse fast enough across the coil to induce enough secondary energy for the plugs.picclock said:The only problem we encountered was that normal ignition points are not happy with very low currents and we had to increase the point current to 50mA (0.05A) to maintain good operation.
If you talk to the military guys, they have to learn electron flow where everything goes from negative to positive.Swede said:For reference, here is a somewhat better representation of what I have running now. I have a hard time getting my brain to think on polarity and having a positive "ground", but the engine doesn't care.
Its quite simple and worth a try.Ken I said:I still think a capacitor across the emmitter & collector will improve his spark - without any other changes - its simple enough to just try it before doing anything more complex.
f there was a way to inslulate the points from the distributor, that system should work with a negative ground.
Swede said:Lakc - on my engine, for the moment, the positive tap of the coil primary is tied to the engine block and thence to the positive terminal of the battery, so this is opposite of what you recommend. That will certainly be an easy fix. Just have to loosen the coil in its clamp, rotate 180 degrees, and re-attach the wires.
So the next step to try is a capacitor across the emitter & collector? Does this need to be as close to the points set as possible? I've got very limited space inside the distributor. Can you guys recommend a capacitor type and value? If I understand correctly, you can't just use any old ceramic cap. Do they sell suitable capacitors for ignitions at lawn & garden stores, for example?
I also need to set it up so I can examine the spark, hopefully giving me a feel for how "fat and hot" it is.
